Home Forum Ask A Member Help ID’ing Michigan Wheel prop
  • #281536
    jimbrizzolara
      I have a two-blade prop in a Michigan Wheel box. The Michigan Wheel number is PJ 300. The box also says the Evinrude number is 376968. The prop is 8 x 7 1/4 pitch. All I’ve found out is that it will work with the 1950’s OMC 5.5 hp motors. Will this prop also work on my 1956 Evinrude 7.5 hp?
      #281548
      MIKE SIMS
        Members have access to Michigan catalogs in the inner sanctum. The 1956 catalog does not show your PJ 300 for a 7.5hp , different size and different pitch.
        #281559
        jimbrizzolara
          Thanks for the information. Looks like I have to buy a 5.5 now!
          #281579
          retiredoz
            The Mich cat says  the std prop for your 7.5 is an 8×8 three-blade, so this should work ok.  Might gain some RPMs depending on your craft.
