Home Forum Ask A Member Help..! Need to ID a small outboard motor
Viewing 10 posts - 1 through 10 (of 22 total)
  • #260525
    DaveEsch
      Good morning everyone
      my name is Dave and this is the first time I have been to your site…
      I picked up a small outboard motor at the neighborhood yard sale a few months back. It has a sticker on it that says it’s a registered Antique Motor Club motor
      I picked it up with the intention of keeping it at our camp in the Western Maine Mountains (Rangely Lakes Region)
      Unfortunatly the ID tag is unreadable so I have no idea what it is.  I was hopeful someone can tell me what the make and model is?
      it appears as if it only has a forward direction or the user swings it around for direction changes
      i look forward to any help and thank you in advance
      #260528
      DaveEsch
        seakaye12
          That is a (modified) Scott Atwater built 3.6 HP with what looks to be a Tecumseh gas tank.
          The original Scott Atwater tanks tend to rust out so someone saw that as a workable solution.
          Great running motors.
          #260531
          DaveEsch
            Thank you so much..!
            the carb has a needle jet on the forward side… it looks as if it may have had a thumb knob or something but it’s missing…
            does that sound correct?
            this jet… is it a mixture jet or something different?
            any idea what the default number of turns is with regards to closed
            Thanks again
            #260532
            Tom
              That appears to be a Scott-Atwater (or Firestone branded Scott) 3.6 hp motor from late 40’s or early 50’s.  The tank and starter are not original.  And because the tank is not original, the correct cowling is missing.  It does not swing around 180 degrees for reverse, only enough to steer right or left.  These are very dependable motors but they have a few things that should be checked.  The water pump rotor is susceptible to swelling if it’s contaminated with grease, or hardening with age.  Parts are available.  Also, if the ignition gives you trouble, the first thing to check is the WICO condenser.  I’m not sure whether the lower unit uses grease or oil, perhaps someone will chime in with that info.  Also, the factory recommended fuel to oil ratio is 24:1.
              T
              • This reply was modified 3 years, 10 months ago by Tom.
              #260534
                The plastic tank resembles ones used on lawn mowers and I have saved a few off dead mowers for just this reason!
                #260535
                  Same idea as this one that I test run yesterday for the first time.
                  It’s a Firestone, made by Scott Atwater.
                  https://youtu.be/_07Z5LZ8T6M
                  #260536
                  DaveEsch
                    thanks so much for the fuel ratio
                    Unknowingly i would have used 32-1
                    I’ll inspect the water pump impeller and lower unit
                    The condenser (fingers crossed) can be rebaselined
                    #260537
                    DaveEsch
                      That’s a cool video
                      looks like my unit but mine is a bit Frankenstein
                      #260545
                        The white paint looks to me an Elgin – scott
