Home Forum Ask A Member Help..! Need to ID a small outboard motor
  • #260560
    DaveEsch
      Regarding the water pump…
      I’m looking at what I believe to be the impeller and from the illustrated parts breakdown it looks as if it has one blade/wiper… is this correct and is it a rubber part or a metallic part?
      Any recommendations regarding a source for the points and condenser, impeller?
      #260562
        463-5100 is what many of us call a “wobbler” impeller, properly called a “rotor”.  They are pretty reliable.  Their main enemy is grease leaking out from the gearcase, which causes the rubber rotor to swell.  That, and sandy water which causes wear of the rotor and aluminum cavity it wobbles in.
        #260619
        DaveEsch
          The points/breaker and condenser in the ignition circuit…
          is it pretty vanilla with regards to the 1970’s era ignition condenser size?
          I have not taken it apart yet but wanted to get the scoop on this…
          thanks in advance
          #260668
          seakaye12
            It’s a Wico Magneto with an unusual condensor and points assembly.  The Points connect directly to the condensor.  Very reliable mag in my experience esp[ecially if it has the orange shellac looking coil.  Just polish up the points and you will probably be OK.
            Wico-Scott-3.6
            • This reply was modified 3 years, 10 months ago by seakaye12.
            #260694
            DaveEsch
              Thank you for the pic… gives me a idea of what to expect…
              side note:
              I was all giddy when I removed the cover on the lower unit and found it in tip-top shape…
              I then removed the nuts securing the impeller/drive shaft assembly…
              the first thing I noticed was a cam shaped lobe and the rubber impeller not bonded to it.
              would I be correct in assuming the cam element is on a spline and tapping it off is the removal process?
              I have made the assumption that the impeller is all jacked up because it is not bonded to the metal lobe…
              #260699
              seakaye12
                Looks good to me.  Turn the driveshaft with the impeller on the lobe and you will see the motion it creates.
                #260706
                  The rubber wobbler / impeller is not suppose to be bonded to the eccentric cam.
                  There’s probably no good reason to remove the cam off of the driveshaft. I’m
                  guessing that the cam is pressed onto the driveshaft, but I’d have to look at mine
                  to be sure.
                  The last two motors like yours that I worked on had a lot of wear in the
                  cavitation plate that the wobbler rides on, from grit and sand no doubt.
                  The first motor, I sanded down the cavitation plate for a new wear surface,
                  the last one I flipped over, but I had to drill a new hole for the pump discharge,
                  and plug the old hole. Hopefully that works out, as I’m putting it back together
                  today.
                  #260707
                  DaveEsch
                    Anyone printing impellers?
                    https://youtu.be/lMu_XNEohjw
                    need a Scott Atwater 3.6 HP Wobbler
                    #260710
                    DaveEsch
                      Unfortunately I could not find a source for the wobbler… knowing the general age of the motor and the general history this makes sense… with that said I suspect reverse engineering/printing the part is the next best option or identifying a source
                      the plate that interfaces with the wobbler looks as if someone fabricated a new one from plate stock… I suspect the original was a hot mess
                      Thoughts?
                      seems like a solid motor… source for new old stock is a bit difficult
                      • This reply was modified 3 years, 10 months ago by DaveEsch.
                      #260720
                        It’s hard to tell from your photo, but your wobbler doesn’t look that bad.
                        Is it still a snug fit on the cam?
