Home › Forum › Ask A Member › Help with 1941 Elto outboard model 4266
- This topic has 12 replies, 6 voices, and was last updated 3 years, 11 months ago by
DennisUnkenholz.
April 24, 2022 at 8:23 pm #258905
I have a 1941 Elto model 4266 outboard and am wondering if one can run it without the exhaust tube? Also does anyone have the busing retainer that connects the water pipe to the housing? If so I would like to purchase one as well as an exhaust tube. Can anyone help? Thanks, Dennis
April 24, 2022 at 8:56 pm #258906Is yours like this one on Ebay?
https://www.ebay.com/p/1927961477
It probably won’t hurt to run it without the exhaust tube, but it’s going to
be annoying loud.
Search Doug and Matt Penn on this site, or the net. They may have parts.Prepare to be boarded!
April 24, 2022 at 9:21 pm #258907Yes it is like the one listed on EBAY but not with the box and accompanying items. It is not in that condition either. Thanks for the information regarding source of parts.
April 25, 2022 at 9:16 am #258917
The ordinal 1 inch outside dia. thin wall tubing that was used
is available but hard to locate. You can search for aluminum
tubing suppliers and see what you can come up with. At the
home centers or some hardware stores with an aluminum rack
you will find 1-1/16” outside dia. thick wall tubing. I have filed
down the top of the thick wall tubing to 1” to fit inside the
exhaust manifold (don’t forget the hole for the above water
exhaust) and opened up the inside at the bottom to fit the
flange on lower unit. Its a much stronger exhaust than the fragile
tubing the motor came with.
Some time ago I found a shower curtain rod at a hardware store
that was the correct 1” thin wall tubing but it was a discontinued
item. I got the last one. This 1” thin wall tubing was also
common on aluminum folding chairs but they don’t usually have a
piece long enough for the exhaust tube.
April 25, 2022 at 12:37 pm #258930anything in the electrical world could fit ???? …metal tubing
April 25, 2022 at 1:03 pm #258931Mcmaster carr has 1″ thin wall tubing
April 26, 2022 at 9:03 am #258976anything in the electrical world could fit ???? …metal tubing
Nothing in electrical. Pluming offers some
“High Performance” options however.
Tubs.
https://youtu.be/3zakS-7_rTgA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
April 26, 2022 at 9:45 am #258983Tubs, I love the Elto Pal “Hot Rod” edition!
April 26, 2022 at 11:11 am #258987
Think I need to up the hp on my
boat registration when running it?
April 26, 2022 at 6:07 pm #259006Tubs,
Thanks for the information. I did find some 1″ OD aluminum at Menards that should work. What diameter is the above water hole and how far is it from the exhaust manifold? Any ideas of how to replace the connection of the water tube and the top of the water pump? It appears there is a rubber grommet that should go there. Thanks all you folks for your help. Dennis
