Home › Forum › Ask A Member › Help with Anzani Minor
Can anyone tell me how to separate the water tube from the water pump housing on an Anzani Minor? The water tube goes through the anti-cav plate, and I cannot open up the lower unit without taking the water tube out of the rear housing.
Thanks,
Tom
GDay Tom
The water tube is a sliding fit through the cav plate and is a sliding fit into the water pump housing below that.
I suggest soaking and heating as required to loosen corrosion that is sticking everything together.
It may take some time so be gentle.
I will post pics if you need them.
Cheers
BnC
BnC, that’s exactly what I needed to know. I’ll give that a shot.
OK
