Home Forum Ask A Member Hiawatha Outboard
  • #2135
    fishman28
      I have a late 40’s or early 50’s Hiawatha outboard that I am looking for some information about. The only numbers on it are 550-393 which is on the block and I believe is the casting number, and the other number is 590003 on the carburetor. Any and all information is appreciated. I already know it is made by Gale Products. Thank you.
      Fishman28
      #21104
        Here are all the Gale Hiawatha models:
        screen shot pc
        #21107
          Actually, 590003 is a crankcase found on the 3hp 1941-50 and probably more.
          #21281
          fishman28
            So any idea what the other number is? It looks just like a casting number on a car engine. It is stamped on the piston housing on this motor. 550-393….with the dash in between the numbers
            Also none of those numbers on the chart are on my motor. Im confused lol!
            #21288
              One would have to assume somebody has removed the model/serial number plate. Your best bet is to post some pictures. That number on the cylinder must be a casting number, does not appear in my parts book.
              #21395
              fishman28
                Ok thanks FrankR Ill post pics as soon as I can!
