Home Forum Ask A Member Hose trick on 10hp 1956
  • #225411
      Working on a 10hp-56 Evinrude and pretty much all done and OK but when I replaced the side air/fuel connector for a “one hose” connector (pump installed) the back end (hose side) of the my new…connector is almost 1/4 inch big !!
      fishing my new “single” fuel line to the new pump proves a challenge because the air/fuel underside opennings on the motor are a rather small and I can’t wiggle a fat 1/4 hose line in the old fuel/air holes
      and special trick or thin wall fuel lines I can use ? drill a bigger new hole underside ?
      #225416
        I drill out the hole in the lower pan.
        #225419
          will do !
          thanks for opinion
