Home › Forum › Ask A Member › How do "you" ID props?
- This topic has 2 replies, 2 voices, and was last updated 9 years, 8 months ago by
Buccaneer.
July 20, 2016 at 2:35 pm #4801
I’ve been going through a box of props that I don’t need, nor
never knew what they originally were on, that I want
to get rid of at Tomahawk.
I’ve wrote down all the numbers I could find, noted rotation,
shaft size, # of splines, etc..
I then proceeded to do Internet searches on each. In some
cases I’d find additional information about diameter and pitch,
but rarely "exactly" what they fit.
For one OMC prop I found info that it fit various motors from
a 1968 55 hp, to a 1984 90 hp. Is that even possible?
What’s the best way to ID props as to what they "fit"?
Below is what I came up with so far for an idea of what
I’m up against. I’m not asking anyone to try to ID each prop
for me, just wondering "how" I can do better. The shaft diameters
were measure in the back side of the prop bores, as some of
them had splines on the front side.
Thanks, BuccanneerProps
1. 3 blade, RH, (MichiganPR 82) 072034, 13-1/8 x 19, 1" shaft
2. 3 blade, RH, (OMC 382764) (13-1/4 x 17) 1.065 shaft. 13 spline,
50 – 140 hp, (needs prop shop)3. 3 blade, RH, (P495) .882 shaft, 13 spline
4. 3 blade, RH, (Michigan PR552) 10 x 12, .882 shaft, Chrysler
5. 3 blade, RH, (T 9.75 x 9.5 P) (48-896892A40) .712 shaft, Mercury
6. 2 blade, RH (48-56238-12) .882 shaft, 11 x 12, Mercury
7. 3 blade, RH, (Michigan PJ 90 cup) 1.065 shaft, (OMC 391199)
13.25 x 17, 13 spline8. _ blade, H, (382763) 13-3/4 x 15, ______ shaft
OMC 1968 to 1984, i.e, 1968 Evinrude 55hp, 1984 Evinrude 90hp9. 3 blade, RH, (293265), Force 50 hp?, 10 x 12, 14 spline
10. 3 blade, RH, 40 hp, .805 shaft, no splines
11. 3 blade, RH, (OMC 307431) 10 x 12
12. 3 blade, RH, (Michigan 072014) 10-3/8 x 10 (Force / Chrysler?) 14 spline
13. 3 blade, RH, OMC?, shaft size .790, Brass hub stamped "D"
14. 3 blade, RH, small, hub b.o.
15. 3 blade, RH, (BWA 5265) Chrysler, 10-1/2 x 15
16. 3 blade, RH, (Suzuki 30840) small, 190 x 150
July 20, 2016 at 3:11 pm #40569As to one of your initial questions, yes, the 1968 55 hp 3-cylinder OMC propeller will also fit up into the 1990s V4 models. Johnson and Evinrude 3-cylinder and crossflow V4s used the same propshaft spline configuration for a generation and then some. Might still use it…
July 20, 2016 at 5:17 pm #40577Thanks Chinewalker, with all those applications I should at
least be able to get rid of that prop!
Was just told that a 13 spline prop is likely for an OMC.
Great tip!Prepare to be boarded!
