Home › Forum › Ask A Member › How does one remove this screw?
- This topic has 5 replies, 3 voices, and was last updated 2 years, 8 months ago by
Bob Wight.
July 6, 2023 at 5:50 pm #277774
Does anyone know how to get to this screw that holds the exhaust tube to the swivel bracket on an omc rd series/ big twin?
July 6, 2023 at 7:33 pm #277782You could use an offset screwdriver to remove the motor mount screw but that would likely be hard to do. I typically just use a screwdriver or small bar to pry the swivel bracket off the motor mount. Just be careful not to break the rubber mount.
"Every time you remove a broken or seized bolt an angel gets his wings."July 7, 2023 at 9:35 am #277794Don’t know how far down you have it torn apart. But removing the nuts from the upper side mounts and one from the upper front mount and then the lower clamshell mounts will allow lifting the whole motor out and up and away from the swivel bracket.
July 7, 2023 at 8:53 pm #277833Thanks everyone for the tips. I got it pretty much all torn down. Now to get it all clean
July 7, 2023 at 9:16 pm #277834While I’ve got it torn apart I would like to take out all of the old grease and get new grease in the steering tube. What grease would you recommend for new grease? Triple guard grease?
July 7, 2023 at 9:31 pm #277835Triple Guard would certainly work. I typically have used Lucas marine grease just because it’s easier for me to find locally, especially since my local Evinrude dealer decided to quit servicing Evinrude motors and quit stocking BRP parts and supplies.
"Every time you remove a broken or seized bolt an angel gets his wings." -
