Home › Forum › Ask A Member › how the heck do you add an attachment
- This topic has 5 replies, 4 voices, and was last updated 8 years, 4 months ago by
outbdnut2.
November 26, 2017 at 3:06 am #8745
error error, its maddening i tell you. i have all these short videos i took for everyone to get a good laugh at a rookie breaking down on the river and getting towed in by the visiting hawaiian outrigger crew that was practicing. not to mention the damn engine coughing jumping skipping etc. i took the videos on my iphhone 7 plus and they are on my mac. I’ve compressed them into a zip file and dragged them to the attachment section. it says downloading and the bar goes from 10% to 50%0 to 100&% and then the damn error message comes up again and again. HOW DO YOU POST A VIDEO IN "LAYMANS TERMS?"
Also. do I………1. reverse the clutch dog, 2. buy a new clutch dog, 3 buy a new clutch dog and forward gear or 4. buy a new lower unit altogether. (there is obviously been one already replaced because it is bright red and the rest of the engine is brick red or that color of Alabama and cream).this is regarding the please help 1957 johnson
November 26, 2017 at 5:36 pm #67957Hiya dobber,
You might be better off hosting your video at a site like vidme or Youtube….and then just posting a link here.
Good Luck,
ChuckNovember 27, 2017 at 4:58 am #67965Videos eat up too much bandwidth.
We don’t host video’s and I think it is a good thing.
Most of the time the lower unit is replaced is because someone hit a big rock. The Brick Red color is probably the maroon color called Johnson "Holiday Bronze" from 1956 30 HP or a 1957 35 HP. If it’s from the 30 HP, although it bolts up and works, it is not built as strong inside. When they upped to 35 HP in 1957, they beefed up the innards. Now – what to buy for parts – take it apart first and see what you need. You may find some really bad things on several parts, making it a better deal to get another used lower unit – you can post a Wanted ad here on the classified board – the ad is free – and you will likely get several offers at several prices. Otherwise, just get the parts you need if it just needs a shift dog and/or a gear. I’d try reversing the shift dog, but the downside is that if it’s so bad that the bad side won’t handle reverse without jumping out of gear, you have to take it apart again, and it gets a bit messy sealing them up as you put them back together.
As for posting a video – the easy way is to post on you-tube, and paste the you-tube web address in your post here.
DaveNovember 27, 2017 at 7:07 pm #67984Hey Dan:
Thank you so much for taking the time to reply to my question. It is a 35 hp engine and that is exactly what I’m going to do. i am going to take it apart.
Do i remove the entire lower unit or just the very bottom by the propeller?
November 27, 2017 at 11:55 pm #67994Best to pull the whole lower unit and the driveshaft and water pump come with it as one assembly – this all comes off easy – then you can turn the whole thing upside down to work on it. I put a thick rag around the housing and clamp it somewhat gently in a vice – upside down, of course. There is a small access cover with two screws part way up the exhaust housing that gives access to a disconnect for the shift rod. It’s also a good time to replace the water pump impeller if it’s old. If you haven’t found instructions for this job online, I strongly recommend you buy an aftermarket repair manual. Seloc and Clymer print them. Se links below, and if you surf the web you may find them cheaper:
The manual will likely help you with future repairs also.
Davehttps://www.amazon.com/1956-1972-EVINRU … +manual%27
https://www.amazon.com/Johnson-Evinrude … +manual%27
