Home Forum Ask A Member How tight should pistons with new rings feel?
  • #305068
    Stewart Mayer
      In our class, on an Evinrude 7.5 7520, some of the piston rings were damaged and I was able to find a replacement set off ebay.  We cleaned out the grooves and put the new rings in. One piston has 1 new ring, the other piston has 2 new rings.  Only one ring was actually broken when we opened up the motor, but we broke two more trying to free them since they were impacted into the grooves.
      I did a light hone before re-assembling.  When turning the crankshaft by hand there are no rough spots, and it feels smooth, however there is definitely more resistance than the other motors that are worn in.  Both pistons feel the same, one does not have obviously more friction than another. I put a digital torque wrench adapter on a 3/4 socket and turned the crankshaft, takes about 20 inch-pounds to rotate it.  For comparison, I tried to take a reading on another similar motor that is smooth-as-butter, but the torque wrench won’t read anything less than about 16 inch-pounds so I couldn’t get a comparison reading.
      This is my first time putting new rings in.  Is the extra resistance normal, and will it work itself out after a “break in” period?  My gut tells me it will be ok, but if there is any advice please let me know, I’d hate to seal up the powerhead and have to take it apart again.
      Thanks!
      #305069
      RICHARD A. WHITE
        “Feel” is not in this conversation… .005 thousands ring end gap per 1 inch of bore, some books say .004 and I have seen as much as .007
        2 inch bore .01 end gap.
        High heat engines need more due to expansion, i.e. race motors that get hot..
        Richard
        classicomctools@gmail.com
        #305070
        green-thumbs
          Others know the subject better, but,I will put my oar in the water,.. Do you recall how it rolled over before you went to work on it? A vefore and after would rule in or rule out causes,  Why was therre a broken ring? Sometimes for some motors both standard and oversized rings were available.. New rings need end gap set by fileing so the have a gap of  roughly 4 thousand per incy of bore diameter,  Some method to prevent ring rotating on piston  may be overlooked an cause binding. It is possible the pistons are 180 degrees out, of position,
          Motors that have take a swim while running can have bent rods, bent cranks or damaged pistons. Usually such parts look ok until they are checked with dial indicator, surface plate or checking fixtrue to pick up twist or bends,
          If you did not set end gap of each ring to cylinder it was to be used in, that is where I would start looking,  If rings ccme in OEM container I would check part # also,
          Good Luck
          Louis
          #305071
            Thanks!
            Well, I would not replace just one of the rings, either replace all of them, or none of them.  But, on this engine that has low compression/RPM to begin with, I wouldn’t worry about it.  The important thing is that it rotates smoothly/evenly through the entire 360 degrees of rotation, which you report that it does.
