Home Forum Ask A Member How to install the cylinder over the piston
  • #9533
    hirschlt37
      I’m rebuilding an older Johnson 2 cylinder opposed outboard. New rings on the piston, the pistons are on the connecting rods…now how to slip the cylinder over those new rings….is there a better way than just trying to pinch the rings together while forcing the cylinder down onto the piston?? The cylinder have a slight taper at the bottom to start the rings into the cylinder…but it’s not going very easy. The new rings have a lot more tension in them and don’t want to come together…appreciate any words of wisdom…thanks, Gary
      #73317
      rco
        A wide zip tie works great for that. Just slide the cylinder on the piston with the rings compressed by the zip tie, and cut it off once it slides past the piston.
        #73320
          I have several sizes if these bolt style hose
          clamps that work well for me anyway.
          #73322
          kirkp
            Tubs, you find those at a local distributor or order them online?
            Kirk
            #73323
            seakaye12
              A lot of us are familiar with Fastenal and I see that they offer a variety of sizes:
              https://www.fastenal.com/products/hydra … mps%22%7C~
              #73324
                I’ve always wanted something like this for compressing piston rings.
                Not sure if these are Russian made?
                http://9motor.ru/eitem/261870383393
                Seen other’s out of plastic for chain saws, but some of the bands are too small.
                https://www.ebay.com/itm/HUSQVARNA-RING … 0217290696
                How to use….
                https://www.youtube.com/watch?v=xYxp8gX1EmU
                hirschlt37
                  Thanks for the comments…I was on the right track…just didn’t go far enough. Tried the zip ties but some issues….will try the type of hose clamp shown…I tried a cheaper version…doesn’t work…I need to cover 2 rings at one time…Gary
                  #73329
                  jerry-ahrens
                    quote Buccaneer:
                    How to use….
                    I have that set made by KD Tools, they work great. The handle is a ratcheting type, so it will keep the rings compressed while you slide the piston in
                    #73330
                    PM T2
                      slice up a pop or beer can with an Exacto knife, Make the width of band you need. Only need one hose clamp for multiple rings simultaneously.
                      Best,
                      PM T2
