Home Forum Ask A Member How to protect transom plywood?
  • #45765
      When I redid mine I used 2 layers of 7/8 inch 8 ply porch plywood coated with 2 coats of exterior latex paint
      never had problems
      #45770
      amuller
        Interesting piece on thinning epoxy:
        http://www.westsystem.com/ss/thinning-w … tem-epoxy/
        #45903
        kees
          International Member
          I don’t understand that
          why using the cheapest crap to mount a collectable motor on your boat
          I use a piece of oak, good and solid
          or if not available, another hardwood
          #45915
          amuller
            So I used some 3/4" plywood made for concrete formwork. It seems of reasonable quality, has seven plies, and a smooth paper on one side. (Dumpster diving material from a nearby bridge project.) Used it on both sides of the aluminum, then had to add more thickness on the outside because of the lip on the transom. So I ended up with about 2 1/16" total thickness. This seems OK for all the OMC motors I checked, and even a Clinton. But it’s not OK for my Elgin/West Bends, limited to about 2". Will need to plane some thickness off the inboard pad, or make a new one. I could have planned this job better.
