Home Forum Ask A Member Ignition coils and laminates
  • #302342
    rjoynt
      I have a 1928 Lockwood Chief. The usual, bad coil. I know that I could go the usual way and try to fit a coil on the existing laminate.
      But looking at it another way, has anyone ever tried to make a new laminate designed to slip new OMC coils on it?
      #302344
        I’ve often thought about it, but never tried it before.
        It seems like when I researched the possibility,
        I got no further than reading about the appropriate material.
        Just “googled it”……
        Top Choices for Magneto Coils:
        • Silicon Steel (Electrical Steel): The workhorse material.
          • Pros: Excellent magnetic flux concentration, improved electrical resistance (reducing eddy currents), better corrosion resistance, versatile grades (GO, NGO), and cost-effective.
          • Cons: Can be brittle and harder to stamp, requiring specific tooling.
        • Soft Iron: Great for simple electromagnets.
          • Pros: Easily magnetized and demagnetized, low energy loss per cycle.
          • Cons: Not as efficient for high-frequency or high-performance applications as silicon steel.
        High-Performance Alternatives:Nickel Alloys: For demanding applications.
          • Pros: High permeability, very low core losses, good over cobalt.
          • Cons: Expensive and requires skilled annealing due to fragility.
        • Cobalt Alloys (e.g., VACOFLUX): For high power/saturation.
          • Pros: High saturation flux density, handles high power well.
          • Cons: High cost.
        • Frequency: Thinner laminations (like 0.003-0.010″) are used for higher frequencies to reduce eddy currents.
        • Texture: Grain-oriented (GO) steel is great for transformers (field along grain), while non-grain-oriented (NGO) is better for motors where the field rotates.
        • Application: For basic magnetos (like in older engines), soft iron or basic silicon steel works; for advanced motors, specialized silicon steels or nickel/cobalt alloys are preferred.
