Home Forum Ask A Member ignition type on a 4hp mdl 40 Mercury
  • #252425
      strangely I look at the ignition coil under the fw and it is almost….. but not exactly a standard magneto coil for a OMC engine
      the diagrams do no not show this type of coil in te marineengine.com listings for a mdl 40 my engine is in 269xxx series and sould be USA made.
      I did not fully take the ignition aprat so I can’T tell if it hasa set of point …
      th capacitor checks out as faulty with my “MOHAT” box looks and test’s like a .020 uf 197 nanoF
      anyone recognize the OMC like coil ignition system ??
      #252426
          FR.. that is the coil πŸ™‚ $25 cdn money I tagged it in my basket in case…. thanks
          anything special about that ignition ??
          update; found a good utube on a 9.8 with similar ignition ( magneto) so onward like a OMC engine πŸ™‚
          • This reply was modified 4 years, 2 months ago by JACQUES.
          #252445
            I certainly don’t know everything; but I have seen a lot of old Mercurys and never a coil like what Frank’s link has. Are those supposed to bolt onto a Phelon mag base plate? Phelon laminations are machined while attached to the base plate; so when you change a Phelon coil, you usually just change the winding assembly, not the whole thing with the lamination. The laminations are also held on by only two screws, not three, which are 1/4-20 thread. In Frank’s link, those are what I think are the Mercury aftermarket part number for an OMC coil. Crosbyman, I would sure love to see a picture of YOUR mag.
            • This reply was modified 4 years, 2 months ago by billw.
            #252452
              Those are my thoughts also. Looking forward to a picture.
              #252454
                coming… see preliminary shot from a CLymer book showing the OMC like coil top left corner of the book scan
                I have one coil one condenser…. will open it up today to see I find a single point set under some cover
                btw the Merc coil would not fit a OMC mag…. bolt holes do not line up this is pure Merc stuff.
                #252470
                  That looks like a phase maker ignition.
                  #252472
                    here are pics of the ignition…. basically nothing complicated πŸ™‚ one set of point to be touched up …..one condenser (to be replaced) and one coil…. testing good…for now !
                    #252476
                      Very educational. Thanks for posting the pics.
                      #252477
                        I realy searched Marine engine site, google for parts on the 4hp ignition … out of interest purely.
                        Can’t find much other than some older posts about the fragility of the points assembly (rocker arm and cracks within).
                        I looked at various mdls finding nothing ??? serial # points to a US made engine . year unknown
                        I have some .020uf mylar (630v) condensers. Mr.Mohat Outboarder article showed preferences for 800V tolerant condensers but i’ll try 630v caps ( his oscilloscope traces did not go much higher than 275V on the EMF kickback traces of the coils .
                        lakes frozen solid so this will take a while to test out πŸ™‚
                        thanks all for feedback
