Home Forum Ask A Member ignition wire
  • #253881
    Boonie
      Can anything other than copper ignition wires be used on outboards. I have a spool of solid core material. Not sure if it will hold tight in the coil or plug boot either. It is 7mm but not multistrand wire.
      #253891
        may work but  not recommended … wire is cheap  don’t risk it    rowing is not fun.
        here is what I install comes with  boots                good for  4x2cyl engines
        https://www.napacanada.com/en/p/BMX700175
        #253893
        JOSEPH BRINCAT
          If it’s solid core, I would be concerned that the core wire will fatigue from flexing and break within the insulation. Copper work hardens rather quickly with flexing.
