Home › Forum › Ask A Member › Impeller on 1952 evenrude an 1953 Johnson
Do you have to pull the head on the 1952 and 1953 evenrude and johnson 25hp motors to unhook shift rod to change the impeller like you do on the e enrude and johnson 5.5 and 7.5 motors. Thankyou in advance for info..
No.
Thanks…where do I separate the shift rod at ?
if you drop the GC an inch or so you should see the shift link connector inside… loosen the bottom bolt
Ok…thankyou Crosbyman..
you should download the bible Johnson service manual … all that info is available for you. see sample picture
https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
the book covers everything you need
I do not have the picture for your model .. some have side plate you can open up to reach the shift connector .
Thankyou…I will try to down load this johnson bible…not sure my phone can handle it…I don’t have a computer
pretty big file ! 178 190 K bites
OK
