Home Forum Ask A Member Initial Carb Settings
  • #235663
    yooperrigged
      Hello,
      I recently picked up a 1970 Evinrude 1.5 hp Mate model 1002R. I was just wondering what the carb settings should be. TIA
      Dan
      #235664
        The high speed needle (lower one) is initially set by turning it 3/4 turn out from gently seated
        The low speed needle (upper one) is initially set by turning it 1.5 turns out from gently seated
        #235668
        yooperrigged
          Thanks Fleet! I sincerely appreciate your help. When I have a serious question I always come here to get expert advice.
          #236393
          Ed@deathwish-outboards
            Those settings are like a universal starting point for all outboards and small 4 cycle engines and that is probably because more of them used Tillotson carbs than not.
