Home › Forum › Ask A Member › Initial needle valve settings JW-10
Can someone give me the initial needle valve settings for the jw-10?
Secondly, verify that the very sharp longer needle is the low speed needle. Thank you for your support.
Correct, sharper needle is for low speed.
In general, most 50s omcs can start with the low speed needle out 1.5 turns from seated, and the high out 3/4 from seated, then tune from there.
OK
