Home Forum Ask A Member Install starter brushes into Autolite MDH 4001M
  • #9606
    olcah
      These starters are used on a 1956 Johnson 30 HP (other mid 50s OMC motors also) but I do not see how to replace worn brushes. It looks like the brush leads are riveted onto the base plate or stators. OMC sold the brushes as a separate set. What am I missing here? How are they supposed to be installed?
      Thank you.
      #73762
        I gave up on replacing those things over 50 years ago. Originals were somehow welded to the fields. Soldering is almost futile. Try it and you will see.
        #73776
        olcah
          Frank, I will just believe you. Thank you.
          #73779
            If they are not beyond hope, just run it. 12V will help.
            #73784
              Electrical starter and alternator rebuilding shops have a electric spot welder to attach the brush leads. I have replaced many. Very easy to do, with the right equipment. These have a problem that shows up on a regular basis. When tightening and loosening the positive cable, the post moves and then the field winding connection to the post on the inside of the starter breaks. It is also repaired using the spot welder.
              #73787
              nj-boatbuilder57
                A new, healthy, strong, replacement motor is about 50 bucks. Just sayin’….
                https://www.ebay.com/itm/NEW-Starter-OM … IR&vxp=mtr
                #73868
                olcah
                  Thanks everyone. This is what I needed to know. 🙂
