Home Forum Ask A Member Interesting times…
  • #283603
      Amazing how  we use technology to  instantly communicate  across the world  via undersea fiber optic  cables or satellite telecoms, to share knowledge/experience    using personnal computers  more powerfull than the original PDP 8-11 cpu’s used  to go to the moon…. to help a stanger  while the same technologies will guide the worst  inventions  created by man.
      As a younger fellow when I started in telecoms in the late 60s  large corporations  had private teletype networks running 75 words a minute , 110 bps modems began sprouting up to  speed things up..a bit.  Then came 300-600 1200-2400-9600 bps modems … eventually  56Kbps  to 1.5mbs yet today we still complain the Net is slow …and we use it all to solve a   problem  on a stuck  2 stroke engine   built 75 years ago
      we live in interesting times.   Happy New Year  everyone.
      #283612
      The absolute best thing about the internet is the great stuff scattered around the world that is put back into use by enthusiasts of all kinds!
      #283756
      John Gragg
        Very insightful Crosbyman.
        I was one of  ‘those guys’ who lived at Egghead Software and upgraded my modems almost annually it seems.
        Remember setting the modem card for the correct IRQ, etc? Then plug ‘n play came along and it was off to the races (sort of), if your OS could handle it.
        Wow. Been a short 40 years…
        John Gragg
        RIverside, CA
        Just starting in the hobby, please be patient.
        48 Sea King 5hp GG9014A. Sold
        49 Sea King 5hp GG9014A
        48 Johnson TD20. Sold
        49 Johnson TD20. Sold
        54 Johnson QD15. Sold
        55 Johnson CD12. Sold
        57 Johnson RJE-19M
        57 Johnson RDE-19
        #283766
        Matthew Pieklik
          My friend” kitchen set died. A 500 set I installed About 40 years ago. I found a phone to replace it. I started digging thru my telephone tools to do the job and started having flash backs. Times have changed and how. I still have my hooks and climbing belt hanging in the garage.
          #283767
          reivertom
            One bad thing about the ‘Net, is now some of my stuff I thought was rare and valuable, isn’t either one!!
            #283770
              Reivertom
              don’tworry… time will take care of it.. price will go up…. one day 🙂
              p.s. 500 set:    common   “hard to kill”  black rotary  dial desk phone or kitchen   🙂
              #283777
                When we moved in 1955 two of these were
                installed by the phone company and my mother
                used them till she passed in 2010. I brought one
                home. We have other wireless ones around the
                house but its the one I use. Don’t have any
                problem hearing on it. Only need to connect 2
                of the wires for it to work today.
                #283779
                labrador-guy
                  Tubs How do you get that old rotary phone to work on a digital line?  You are amazing us again!
                  dale
                  #283781
                    Just started connecting wires to the junction
                    box till It worked???
                    I have our old touch phone, the ones with the
                    key pad that make a tone when you push the
                    buttons, in the wife laundry room. Works fine.
                    I’ve heard that the old crank phones will ring
                    and you can talk and hear but you can’t dial
                    out. Lots of old stuff besides outboards
                    (including me)around this house. We try to
                    keep it all working.(including me)
                    Probably Mr. Pieklik can answer that question.
                    #283787
                      to answer that one is easy… if I may
                      Digital technology that replaced central office relay switching works the  same way   when capturing  rotary dial  pulses generating  make and break   loop current at  45-65 % percent break.   Later  came  touch tones  on the  basic  service… to charge you more  money 🙂 while  saving  all the maintenance $$$   on the clink-clank relays  technology.
                      Digital  ” line cards” simply capture the  on-off current  pulses on the phone loop   as a   stored digit     and  converts it  to ” signalling/routing)  information”  to be processed further down the system .  The accumulated dialed numbers ( 1 to 0) interspaced by  ” inter  digit timing”      are  accumulated  to form  a destination  #  according to the  Number Plan Area  +Exchange NXX & xxxx  format.
                      Computers then  first  define  the call  as local or LD  & establish  a  point to point connection and  pass on network routing  info to both  calling  and called parties  ( dial tone, ring tones   busy tones, ” no such number  tones, netwrok messages,  called ID)    etc..)
                      Upon getting a signalling reply  (off-hook loop current ) from the destination the voice component  is established between parties.  All this is done  in an instant
                      sound quality wise… old networks carried  300-4000 hz  bandwith for human ears… today everthing  is  sampled, encoded,  reassembled  using complex algorithms to  recreate sounds … no wonder  ” bits” of it are lost on the way 🙂
                      Concept wise … nothing new under the sun.   remember when phone  serbvice was $18/month  🙂
                      One problem…with rotary… not so good to fetch /control voice mail unles you link it to a  separate  touch tone pad  🙂
                      back to OB’s
