Home › Forum › Ask A Member › Is there a decent plastic gas tank sold today that vents?
- This topic has 10 replies, 8 voices, and was last updated 8 months, 3 weeks ago by
Timguy.
July 13, 2025 at 10:00 pm #298160
Hello:
I’m trying to find a good quality 6 gallon plastic gas tank to use with my 1970 Evinrude Triumph 60 HP. The old OMC metal tanks had a vent system, which prevented vapor lock. Looking at many of the plastic tanks offered today, they all seem to have various pressure release functions, but I haven’t seen one that has a good old fashioned vent. Can anyone recommend a good tank (would ideally have a fuel gauge on it) that has such an old school vent, or perhaps a good one that I could then swap out the cap with a vented cap…. next question would be would anyone know where to buy such vented cap….. Thanks for any thoughts!
July 14, 2025 at 1:22 am #298161When looking at fuel tanks, I would reccomend paying attention to how far down in the tank the top of the fuel pickup is (specifically, the top of the mesh). I unfortunately wound up with a fuel tank that has the fuel intake high up inside the tank, and it’s a veritcal intake. What I mean by that is the cylindrical shape of filter mesh faces the same way a can/tin of soup would sit on the counter. Older metal OMC tanks (not the pressure tanks) had the fuel pickup tube shaped like a capital L, and the mesh was only on the lower part, so in the same orientation as a rolling pin sitting on the counter. Consequently, there will still be lot of fuel in this newer style tank when the fuel level is low enough for the top of the mesh to become exposed and the motor start sucking air. This reduces your range on the water and is more wasteful (if you replace last season’s fuel every spring) than the OMC tanks with the lower pickup. Looking through the gas cap of the tank on display in the store should give you a clue of the setup of that particular tank.
Why don’t you stay with an older metal OMC tank? If yours became completely rusted out, there are still many used ones available as replacements.
July 14, 2025 at 7:17 am #298164Thanks, Sam. I restored two of the old style tanks, and even with proper prep with the Kreem tank liner product I’m still getting flakes of rust in the tank, which I think are getting sucked up against the pickup, thus causing problems while running the boat; I’m trying to rule out causes of the running issue, so thought I’d look for a good plastic tank. My preference would be to use the OMC tanks, so I may end up looking for rust free replacements. Thanks
July 14, 2025 at 9:50 am #298167I just wish there was a plastic tank that would not swell up
July 14, 2025 at 9:54 am #298168I just leave the vent screw open a bit. That is after I cut the little nipple under the vent screw so that it will actually vent!
July 14, 2025 at 1:51 pm #298170I just found an OMC 6 gal tank for Evinrude/Johnson at a local dealer that has the OMC fitting on it, a gauge, and the cap has a rubber ‘duckbill’ on the underside which he tells me will let air into the tank, but not out of the tank. So I’m going to see how it goes.
July 14, 2025 at 5:16 pm #298174I don’t know if a plastic tank is safe or practical for outboard fuel tank, but there are conversion kits to change a new style safety spout type to an old style free pouring with separate vent. Possibly sold at Tractor Supply or Harbor Freight stores.
July 14, 2025 at 8:36 pm #298183I just found an OMC 6 gal tank for Evinrude/Johnson at a local dealer that has the OMC fitting on it, a gauge, and the cap has a rubber ‘duckbill’ on the underside which he tells me will let air into the tank, but not out of the tank. So I’m going to see how it goes.
That “duckbill” is what I clipped. Before I clipped it, it would let air in but not out so it swells!
July 15, 2025 at 9:21 am #298198.
My choice for a spout, for the plastic 1 & 2 gal. gas containers I use for my motors, that have tanks on them, is the Midwest Quick Flow Spout– with modifications. The gas stops flowing when it gets to the tip of these spouts. First I take out the red lock. The small tab on the spout isn’t big enough the keep the spout from sliding off. I put a hole in a cap from another container with a friction fit on the spout. Adding caps controls the level in the tank when the fuel stops. Helpful in really small tanks like Pal’s, Cub’s, ¾ hp WW,ect. Need to lubricate the spout with some oil in the spring. When plastic tanks expand, when they get warm, and contract when it gets cooler, air is not moving in and out of the tank. It’s also not letting in the moisture that’s in the air, into the tank, that leads to water in the gas, and rust inside metal tanks.
July 19, 2025 at 12:17 pm #298299I just found an OMC 6 gal tank for Evinrude/Johnson at a local dealer that has the OMC fitting on it, a gauge, and the cap has a rubber ‘duckbill’ on the underside which he tells me will let air into the tank, but not out of the tank. So I’m going to see how it goes.
I have one of those OMC 6 gallon plastic tanks that I got used 25 years ago; and, it works great, and the minor swelling has not been a problem…..or it did work great until the rectangular black assembly that contains the gauge and fuel line connector developed a hairline crack and leaked when the tank was nearly full. The material looks just like the cast aluminum part on the metal tanks, but it is plastic. The crack was so hard to see, that I thought for a while it was seals on the connector leaking. I took that part off a metal tank and it fit the plastic tank perfectly, except have to play around bending the gauge float wire to get the gauge reading properly due to differences in the geometry of the tank. I like that tank and would buy another if one showed up near me at the right price.
For aftermarket 6 gallon plastic tanks with the gauge and a vent screw in the filler cap, there were a zillion of those sold, and Yamaha also used them in the early 2000’s with their name private labeled on the tank (my 2004 25 HP Yamaha on my pontoon came new with one). I was given two other tanks like that over the years, but the lens in the cap for the gauge eventually goes bad and comes loose or cracks, producing a bad fuel leak as gas sloshes around in the tank. The manufacturer is out of business due to lawsuits from fires resulting from these leaks, and for that reason, you can’t find replacement caps that have the proper fit and depth of the gauge float for these. I found a Briggs and Stratton replacement garden tractor cap that screwed onto these tanks with a couple pin-hole vents that are open all the time, but when the tanks were near full , they leaked gas out the vent as you bounced around hitting waves and/or cornering. I threw those two tanks away because I couldn’t find suitable caps. Maybe somebody now makes a cap with a vent screw that will fit and not leak?? otherwise, I will throw out my Yamaha tank when the non-replaceable gauge/lens/cap breaks or comes loose – it has turned yellow and you can’t see through it anymore to read the gauge. Meanwhile, it is not in an enclosed compartment, so risk of fire or explosion is minimal.
