Home Forum Ask A Member Johnson 1947 po 15
  • #176779
      What do I use in the lower unit? grease like 105 or 80-90 oil
      thanks
      chuck86
      #176819
      lloyd
        I can’t remember now exactly what type seals were in that gearcase, but I am pretty sure that Lubriplate 105 is the best choice.
        #176828
        George Emmanuel
          The lube you need to use is dependent on the wear/tolerances of the propshaft and the pinion shaft, but mostly the propshaft bearing. If there is significant wear (slop) then you’d need something that won’t rapidly flow out, i.e. “heavier” grease. 105 is pretty thin.
          George
          #176838
            https://www.youtube.com/watch?v=oaaDUyIX2kI
            • This reply was modified 6 years, 8 months ago by Tubs.
            #176942
            outbdnut2
              In my PO-15, I have used water-resistant grease marketed for boat trailer wheel bearings. Yes that grease was thick -it looked like Lubraplate 105 – may have been the same thing rebranded. I made an adapter so I can pump it in from the cartridge with a grease gun. First I took the lower unit apart and cleaned out all the old gunk and some rust. Who knows what was put in it over the years.
              David Bartlett
                I use Corn Head grease in my PO with great results.
                David Bartlett
