Home Forum Ask A Member Johnson 1953 QD-14 10hp
  • #6423
    hmai
      I have a few questions about a QD-14.
      I picked this up last summer and used it for a few weeks until I noticed some water in the lower unit and it started to sputter/kick at WOT. I assumed the clutchdog was bad, but actually looks like new.
      1.Anyone know where I can get the seal kit for this. I was hoping not to have to piece together each ring/seal seperate.
      2. Is there an adjustment for the shift rod. I know my 57 and 58 have none and was hoping to give it a touch more towards forward.
      3. I also wanted to go through the carb clean and replace packing washers etc. Is there a kit available for these. I have rebuild several late 50’s, but it is my 1st pre 54. All I can find is the bowl gasket. Anything needed for the primer/float etc.
      Thanks,
      Herb
      #53587
      wedgie
        Chris P has a seal kit already put together for your gearcase.
        http://www.myoldboatmotor.com/
        Vintage outboard.com has the powerhead gasket kit
        http://www.vintageoutboard.com/collecti … hp-1951-54
        #53607
        seakaye12
          Hmai…if you don’t already have a parts manual for your motor but would like one….send me a PM with your e-mail address and I will send you a PDF.
          #53615
            HMAI… check your PM,s
            #78111
            mhousand
              Can you send me the owners manual PDF? mhousand.housand@gmail.com. Thanks
              #78131
                happy reading …
                http://162.144.28.33/lib/johnson/manual … hnson.html
