Home Forum Ask A Member Johnson 1958 18 hp
  • #11248
    dietzer
      Anyone know what a stock brand new motor compression would be on this model? Want to buy a old new stock motor, but wanna make sure it’s new still. Not almost new.
      #83091
        Based on motors with very low hours I have found, I believe the 18s had about 145 psi brand new.
        That aside, for every 100 motors I see that are advertised as NOS/Never Used, I would say maybe 5 percent are accurate.
        #83219
        lloyd
          I have found that the OMC 18’s need to have about 125 PSI cold and dry to run and idle well.
          #83316
          shane-r13
            My 1959 Evinrude 18hp Golden Jubilee LOW (stored since 1975) hour motor has 125 psi top and 122 psi bottom. So I would say a NOS should be higher.
            #83323
            chinewalker
              Chances are you will not see anything remotely "accurate" as there is great variation between gauges. Best you can hope for is to have the motor be over 100psi in both cylinders and no more than 10% variance between cylinders. This is why you’re not likely to find published compression readings in any OMC produced shop manuals.
              Actually, a brand new motor will likely have LESS compression as the rings are not yet seated in their bores and haven’t gone through any break in period.
