Good point. The 200 doesn’t have a water pump and uses the pressure-vacuum system found on other Johnsons of the era. The discharge outlet is under water, in front of the prop.
OOOOOOO, so the only way to tell if the water is in fact running through the system is to put your hand near the cylinder and see how hot it is? OUCH!
