Home Forum Ask A Member Johnson 5.5 finally out on the lake….
  • #5517
    amuller
      Motor runs nicely–not much power, of course, but hums along smoothly and starts with a small tug. I have only a couple of issues to resolve:
      The throttle linkage does not seem quite right:
      Lever at the top of the vertical shaft smacks the inside of the hood. There does not seem to be opportunity for the gears to be meshing incorrectly, and I do not see any limits to total travel. Am I missing something here?
      The position of the red dot on the twist grip does not seem to correspond with reality. For example, the motor barely runs at the "shift" mark, not fast enough to keep going with the sudden prop load. Are there any relevant adjustments?
      Perhaps these two things are related?
      am
      #46022
        Can you post a picture of the lever?
        The tiller bands are just a rough guide at best of times.
        #46053
          Well, I agree, don’t think the big throttle handle gears can be misaligned. But, the smaller gears next to the vertical throttle shaft could be misaligned. How did you determine that the linkage is hitting the cover? The grip indicator and sleeve rarely line up properly like others have said.
          #46054
          amuller
            I heard the lever hitting the cover. And there are marks on the inside where it hits.
            I pulled out the vertical shaft and the gear that rotates it, and the teeth are one-for-one. I don’t think it can be meshed out of time, at least not without its being obvious.
            This isn’t really interfering with the operation of the motor, but I doubt OMC designed it to hit, so I’m bugged to figure it out.
            Here is the requested pic:
            Funny: Yesterday I was offered one of these motors, with tank, for $50. I don’t know if it was stuck. I controlled myself and passed on it. Probably should have bought it for a winter fix-up and sale in the spring.
            #46062
            Doug Wilson
              some times can adjust the teeth on the gear from the throttle handle a tooth or so. They do not have a ton of power but are extremely reliable and if tuned well usually start on the first or second pull all day long.
              Doug
              turned off?
              #46064
              retiredoz
                Pull the vertical lever and check the part number vs what Marineengine says it should be. There are a zillion flavors of that rod..
                #46067
                retiredoz
                  This is what it should look like, from your picture it seems your lever is askew ?
                  https://s13.postimg.org/r7y11h93b/john61.jpg
                  #46071
                  wedgie
                    Is it twisted like a candy cane?
                    #46078
                      This is what Wedgie is talking about, this came off My 57 FD11 18hp.
                      #46086
                      wedgie
                        Yep. That’s what I was talking about. I have one like that somewhere here too.I was at work when I posted earlier so didn’t have time to elaborate 😉 .
