Home Forum Ask A Member Johnson 5.5hp (CD-16) driveshaft bearing plate
  • #6968
    daffyjeffy
      I need a bearing plate for my 1959 Johnson 5.5hp rebuild (CD-16). I cracked mine trying to extract the old seal. Thanks!
      #57381
      wedgie
        They are available new(reproduction) at Marineengine.com but a bit pricey. Ebay has them used or occasionally new old stock.
        https://www.marineengine.com/newparts/p … OMC0382796
        Maybe a member local to you has one to spare . Where you at?
        #57382
        daffyjeffy
          I’m in Maine
          #57383
          wedgie
            Put an advertisement in the free classifieds section here and you might get lucky. Another option is to keep your eyes open in your local Craigslist for a cheap parts motor. It may take a while but eventually one will show up as they used that same part for many years. They are getting harder to find though.
            #57384
            wedgie
              Maybe this guy has a spare eh!
              https://maine.craigslist.org/bpo/6117519758.html
              #57387
              daffyjeffy
                Thanks for the help and suggestions. Really appreciate it. 🙂
                #57392
                1946zephyr
                  Yea, those were commonly wore out. If the bearing surface didn’t get chewed up from the shock absorber then the often blew out, when the shock absorber spring grenades out. Ouch. Yes. Quite spendy 😮
                  #57393
                    Shoot me a PM if you cannot find one locally Daffy.
                    When buying one, ensure that the bottom surface isn’t mushroomed or damaged from a blown shock absorber as Zephyr mentioned. Very common to find them damaged.
                    #57409
                      If Richard has a CNC setup, he could start spitting these out by the gazillions!
                      #57416
                      davidk
                        quote DaffyJeffy:
                        I’m in Maine
                        We have a very active chapter here in Maine. Come to a meet!
                        http://pinetreeboating.com/pinetreeboating.com/Dougs_Meet,_2016.html
