Home Forum Ask A Member Johnson 51 Sea Horse TN27
  • #9824
    51seahorsetn27
      So its more than likely been asked or said but;
      I have a 1951 Johnson Sea Horse TN27 and am in need of engine clearences and specs and enventually in need of parts, mainly as of now I need ring end gap, crank end play, all crank journal diameters, rod big end side clearence and inner diameter, con rod bolt torque specs, main case 6 studs torque specs, and the 4 main case cap screw torque specs. If any one has a service manua,l I would be interested in a copy some way some how. :ugeek:
      Thanks in advance,
      Malcolm
      #75345
        I have the service manual on my hard drive, but it is also on-line somewhere–but I don’t remember where. I’ll bet somebody will come along with the answer soon.
        #75347
        51seahorsetn27
          I hope so, I been searching for one for ever, with no dice, my e is eighty hot rod at g male dot c0m if anyone comes up with it in a pdf or doc format etc
          #75359
            http://pochefamily.org/outboard/
