Home Forum Ask A Member Johnson 57 3hp runs on only bottom cy
  • #184568
    scubachuck
      Replaced all electrical has good spark on top cy but top of piston is dry
      #184573
        How is the compression? Exhaust ports blocked on top cy/inder?Broken or misaligned reed valve on top cylinder? Hole in crankcase on op cylinder?
        #184576
        scubachuck
          compression 60 both cylinders
          Does each cylinder have it own reed ?
          If i put a little gas in the spark plug hole i can get it to fire
          #184607
            Yes, each cylinder has it’s own reed
