Home › Forum › Ask A Member › Johnson A-25 needle valve packing
I am finally working on my a-25, what can I use to replace the needle valve packing and also the carb bowl gasket? Thank you in advance!
I used a piece of 1/8" leather for the needle valve packing,used a set of leather punches I bought on the bay to do it and used 2 back to back. No leaks at all. Bowl gasket you could try some 3357 fiber/rubber gasket material from fel-pro.
Thank you, will give that a try
OK
