Home › Forum › Ask A Member › Johnson A 35 cooling problem
- This topic has 5 replies, 3 voices, and was last updated 9 years, 8 months ago by
ronboonville.
May 24, 2016 at 9:16 pm #4348
Another member gave me a 1927 A 35. I got it running today but it runs really hot! Could someone provide an exploded view of this motor? , before I start taking it apart. I could not find a tell-tale for the water. Does it have a pump?
May 24, 2016 at 9:53 pm #37098There is no tell tale. Water is picked up by the openings in back of the propeller, and pulled out at the ports in front of the propeller. Unlikely that you could get it to Cool in a barrel. Try it on a boat if it runs OK. Once running, get it up to half throttle or so, then you can idle it back.
T
May 25, 2016 at 1:01 am #37119Thanks Tom, no pump! Removed lower unit, will tear that down in the morning. feels like rough bearings or gears when I turn the drive shaft.
May 25, 2016 at 10:06 am #37140Ron, Tom is correct. The pressure/vacume cooling system used on the A35 will not function in a test tank or barrel. You really need it on a boat. Those motors are usually easy to get running… probably the best running antique outboard around. Enjoyed having you at the MAPS meet at Pomme.. glad you could make it! Seeing you run your Elgin makes me want to get to work on my 12 hp.
May 25, 2016 at 11:13 am #37142The lower unit has a unique feature that may be unfamiliar… There is a spring loaded brass cone which is supposed to slip if the prop hits something. Two problems can show up with this. First is that the cap that tensions the spring has loosened, and the assembly slips under load. The second is that the cap splits and there is no tension on the spring at all. I’ve seen several of these with broken caps in the larger K series motors of the same era, and a few in the A series. It’ll take a while, but you should probably go through the whole lower unit.
The large aluminum nut on the front of the gearcase is the locknut for the gear mesh adjustment. With the nut loosened, you should be able to adjust gear mesh by turning the slotted carrier with a screwdriver. When you get to the point where you are reassembling the lower unit, get back to us if you have questions.
T
May 25, 2016 at 7:51 pm #37163Thanks Tom for the info, and Thanks Jerry for the great meet!
