Home Forum Ask A Member Johnson A50 A A25 shear pins
  • #10173
      Ok, the 1930 Johnson A50 uses a brass 9/64 dia. x 1 5/16 long shear pin. Any body have a source for 9/64 brass rod? I have tried hobby shops, welding supply houses and general building supply companies. The earlier A motors also use this size pin. Help
      #77514
        how about 1/8 stainless steel?
        #77515
          0.1486" or 3.57 mm, between #27 gauge and #28. Sand down a 5/32" rod ? ? ?
          Garry in Tampa
          #77520
          rpsiii
            You could always go to eBay and get the proper Olson #10 brass shear pins (9/64"
            X 1 5/16") for your motor.
            There are at least 3 offferings for Olson #10 brass shear pin packets in that size in various quanities and prices.
            Just thought I’d mention it!!
            Respectfully,
              Thank you for all the suggestions. I am looking into Ebay listings.
              #77557
                I drill out the prop shaft another 64th to
                5/16. The prop seem to accept the slightly
                larger pin OK.
