Home Forum Ask A Member Johnson AB-25 Lower Unit
  • #161367
    muddog2
      Trying to figure out how to change oil in lower unit. Do I also have to take the prop off and grease where it goes on the shaft? What lube is recommended. I am planning on using this engine.
      Robert
      #161377
      lyks2tinkr
        The LU on those motors use grease. Lubriplate 105 will work but I find it a bit thin so I use something a bit more substantial like John Deere corn head grease or equivalent.
        There are screw plugs in the LU I believe but to clean it out good I would remove the prop and prop shafts cover.
        As a side note, you may want to check and make sure you don’t have grease in the water pump piston. The piston can wear and allow grease to get by and gum up the pump.
        • This reply was modified 7 years, 2 months ago by lyks2tinkr.
