Home Forum Ask A Member Johnson AB-25 Restoration
  • #11629
    muddog2
      Here is a Johnson AB 25 I have been working on. Trying to get it running again. Has compression and the previous owner said it ran 5 years ago, but the wires got hot so he turned it off.
      Progress
      Robert
      #84733
      muddog2
        The kill switch wire on this motor is a braided wire. The cloth casing is coming off and I was doing renovation on a 1930’s house and got some telephone wire that is the same size with good casing on it. The wire is a single wire. Will this work?
        Thanks, Robert
        #84734
        stanley
          Should work.If it doesn’t,you’ll know when you lose spark or the engine won’t stop when you want.
          #84742
            Your motor has the very desirable brass/bronze gearcase and A/V plate on it!
            #84744
            PM T2
              Lower unit aside, the real desirable part on this motor is the wood tiller handle originally wrapped in leather. Save that puppy. Repro-s are selling for north of $50 US and they are good repops, but not exact copies (slight dimensional differences make the repops larger than originals)
              Best,
              PM T2
              #84749
              muddog2
                Thanks, if I get it running, I will not use the original handle when I take it out.
