Home › Forum › Ask A Member › Johnson AD-12 mystery
- This topic has 47 replies, 15 voices, and was last updated 9 years, 2 months ago by
Don.
January 7, 2017 at 9:13 pm #50573January 8, 2017 at 5:59 am #50612
Looking close at your pictures, you can see where the flywheel is dragging on the magneto plate. As you have likely already decided, I think the flywheel is the problem.
There are several on the internet ePay site right now. Part # 580217
Good luck.
January 8, 2017 at 12:30 pm #50617There is very little clearance for the ignition component wires. In one of the pictures, there is a bright green wire from the good coil to the points. That wire needs to be routed underneath so it doesn’t rub on the flywheel hub. It looks as though it may just be starting to rub?
Improvise-Adapt-Overcome
January 8, 2017 at 6:34 pm #50652January 8, 2017 at 6:52 pm #50655January 8, 2017 at 7:15 pm #50661Yeah, she broke the throttle lever. That is on the parts list.
Located in Green Bay, Wisconsin
January 8, 2017 at 9:31 pm #50674I took another look at the pictures. I notice that the two long screws that attach the coils to the armature plate base are missing. These two screws, along with two short screws on the plate itself are all that holds the armature plate down to the base. I am wondering now if the plate is not seated properly and is causing the contact with the flywheel?
January 8, 2017 at 10:15 pm #50680quote 63LSTriton:Yeah, she broke the throttle lever. That is on the parts list.Located in Green Bay, Wisconsin
Wisconsin ! you should have no trouble finding parts close to you.January 9, 2017 at 10:58 pm #50757Well, the brass ring and retainer seem to be correctly oriented. The crank does not appear to be galled from aluminum transfer either. I would start with trying a different flywheel, which is the easiest place to start.
Someone raised a good point about the missing fasteners, perhaps the mag plate is just being drawn upward because it is loose. I realize the screws are missing because you pulled it apart for pictures. Nonetheless, reinstall the fasteners, then try lifting up/down on the mag plate to see if it is loose for some reason. And, it is surely possible that someone pried up under the mag plate while trying to remove the flywheel in the past, which may have bent it.
And yes, once the clearance issue has been resolved, that ignition system looks to be in tough shape.January 10, 2017 at 4:15 pm #50780crooked flywheel notwithstanding ….
anyway a spacer washer under or over the cam lobe would help lift the flywheel enough to clear the mag plate….?
i know it is not design intent but…. if it solves the problem without affecting the rub blocks on the point arms…
all that seems needed here is 1/16 or 3/32 spacing to clear the mag plate if no cure is found for this mysterious problem
