Home Forum Ask A Member Johnson AD-12 mystery
Viewing 8 posts - 41 through 48 (of 48 total)
  • #50787
      A spacer washer would lift the flywheel off its taper. The flywheel has to be tight on the taper.
      #50795
      63lstrition
        Thanks for all of the replies. I will try to have her order her parts and see about an alternate flywheel to check fit. Regarding the spacer, i was thinking of trying a shim, but didn’t know how to make it fit on the taper
        other comments:
        – all of the mounting hardware that hooks to the retaining ring are off for troubleshooting and picture taking.
        – good catch on the wire routing. we were going to address because it was dragging. the black you see in some of the picture is liquid tape….
        – we do have "good" coils to replace the one that was euphemistically called "NFG" Don’t remember why we had the bad one in, but I think it was just a place holder as we swapped around components
        – right now we are in a holding pattern until she orders her parts. I am going to jump on the part order for some FD-10 parts too so I can get that one rolling.
        #50797
          Just to be clear, do not attempt to "shim" the flywheel up for the reasons that Mumbles stated….
          You mention ordering parts, please do not attempt to order a "new" flywheel and/or mag plate. These parts are probably NLA, and would be very expensive if they were available.
          Where are you located? I’m sure there are members nearby who can supply good used pieces at a reasonable price. I know I have a flywheel and mag plate laying around somewhere. I would be happy to supply these items NC, but I’m sure the shipping won’t be cheap….
          63lstrition
            Located in Green Bay, Wisconsin
            #50827
              Any members near Green Bay that can help guys??
              #51282
              63lstrition
                just tickling this back to the top to try to find a local member.
                #51283
                  quote 63LSTrition:
                  Try starting a new thread with your question! 😀
                  #51322
                    I would be willing to send you a flywheel and mag plate, just pay the shipping…
                    PM me
