Home › Forum › Ask A Member › Johnson CD & RD Crank taper question
- This topic has 13 replies, 8 voices, and was last updated 7 years, 6 months ago by
garry-in-michigan.
September 7, 2018 at 2:03 pm #11102
Good Morning…..
Can anyone tell me whether a Johnson CD (5 1/2 hp) and a late 50’s RD (25 hp) are the same? I need a ‘heavy’ flywheel for a Frankenstein CD I’m working on. I know it won’t fit under rewind or cover……that’s ok.
Thanks for any info!
Jim
September 7, 2018 at 2:15 pm #82394No, taper is same angle just different diameter
classicomctools@gmail.comSeptember 7, 2018 at 2:41 pm #82396Hmmmmm. Back to the drawing board. Making a spacer sounds kinda’ fussy….
Thanks, Richard!
Jim
September 7, 2018 at 4:16 pm #82398That would be challenging, not saying it can’t be done, just lots to consider when looking at that from 5 feet away..
classicomctools@gmail.comSeptember 7, 2018 at 8:55 pm #82407Try an FD 18 or 20 horse flywheel as they have the same taper. A CD 10 horse flywheel will also fit.
September 7, 2018 at 9:00 pm #82408I have to ask…..why would you want a heavier flywheel??
September 7, 2018 at 9:06 pm #82409How ’bout an 18-20hp electric start flywheel with a thicker ring?
Trying to make a super slow trolling motor, ain’t ya?
September 7, 2018 at 9:35 pm #82411Although it would be beyond my abilities, a shrink fitted steel band, perhaps cut from a piece of pipe and machined to size, would add that all-important rim weight.
September 7, 2018 at 10:39 pm #82416quote :“Trying to make a super slow trolling motor, ain’t ya?”Frank’s right….sort of. I’m trying to cheat up a motor for a"’How Slow Can You Go" idle contest….. Old racers are all the same. In the infamous words of Junior Johnson…"There are two kinds or racers: cheaters and losers…"
As usual…thanks for any input!
Jim
September 8, 2018 at 1:29 am #82425This begs a question I’ve had in the past. I have seen numerous conflicting directions on how to install the flywheel key. Some say key face parallel to crank centerline and others say key face parallel to crank taper. I have a copy of an Evinrude service bulletin somewhere that clearly indicated parallel to taper. So which should it be? And does it perhaps differ according to motor HP size?
"Every time you remove a broken or seized bolt an angel gets his wings." -
