Working on the first winter engine project of the new year and finishing up the top end of a Johnson DT38. According to the service manual I have (4th edition) the brush arms coming off the coil need to be aligned to run on the inner hub of the flywheel and tool SE262 was used for that purpose. Looked to me like a block of aluminum that fit over the tapered flywheel spindle and the thin metal brush arms were supposed to touch the outer edges of the block to align them. I’m figuring the SE262 alignment block tool is scarce nowadays so pretty much I have to measure the outside diameter of the inner flywheel hub and bend the brushes to that measurement and test fit. Has anyone dealt with the brushes on the Johnson dt or ls,lt engines? They all seem to have the same coil/brush setup and I have a DT10,Ls37,and Ls38 to tackle after this project. Also looking for a transom bracket for the DT38 as one side of mine is broken and missing.
