Nice little projects you have there. Easy to work on , hard to find parts, the coil being the main challenge. They use a metal water pump impeller and grease, not oil, in the lower so that’s simple .
One thing you’ll need to do a bit of studying about is the poppet valve/ carb combo. Not voodoo science, but unusual.
