Home Forum Ask A Member johnson fd-11 1957 18 hp
  • #258130
    John Vaivoda
      fd-11-lower-unit-leak
      Is this hole on the top of the lower unit supposed to be there to drain out water? I know the lower one on the side is, but am not sure about the upper one that is draining out oil mixed with water. Both holes are draining oil water mix. I am assuming the drive shaft seal under the impeller  needs to be replaced? I am replacing the prop seal also while it is apart.  Also was wondering if that which is draining  is just from the what ends up being dirty filthy oil water from running it in the test barrel, but I don’t think so. I only ran it a couple of minutes, and the water wasn’t That Dirty! See picture below.  Aslo, I can’t get the top cylinder to stop misfiring. The new points are flush, and it is timed with a timing tool. I replaced the spark plug wire also. Wondering if the coil is throwing intermitten spark? Thank you so much for anyone of you that can help. sincerely, John V
      #258142
        I see you are a new member .. If not already done (sorry if I repeat myself) download your self a copy of the RED  johnson  service manual to service your oldy go to
        MEMEBERS ONLY TAB…INNER SANCTUM TAB …find LIBRARY… find GARRY SPENCERS DROP BOX…find the RED Book PDF  & download… print locally in 2  binders of 200 pages 🙂
        if your GC oil is not contaminated   holes are just drains  and seals  are ok
        recheck points  and clean again    condenser may be bad    if coils are cracked  replace  ….top coil may be  shorting out when hot (check for burns)
        #258145
          deleted
          • This reply was modified 3 years, 11 months ago by JACQUES.
          #258151
            That is not gear oil.  It is the oil that you mixed with the gas.  It has gone through the engine, some burned (smoke) and the rest out the exhaust where it emulsified with water,   Probably agrivated by the mis-firing and bucket-running.  Get it running correctly, and on a boat where it was intended to run, and adjusted properly, and it will run much cleaner.
