Home Forum Ask A Member Johnson HD 25 head frost plug
  • #242198
    Champion1
      Does anyone know where to get a frost plug for the head on a 1947 Johnson HD 25 2 1/2 hp
      #242215
      yooperrigged
        I believe I have the whole head if you want that.
        Dan email me at:
        yooperrigged@gmail.com
        #242224
          What’s wrong with that one? If it’s leaking, you can clean the area and apply some epoxy to seal it.
          #242242
          lloyd
            Spark Plug threads are also in rough shape.
            #242295
            Champion1
              Yes this is the old one. The new one is good except its missing the frost plug. I was just using the picture of the old one to show the plug that was supposed to be in the head I purchased. I should be able to come up with a plug for the hole on the new one without too much trouble.
              Thanks for the replies fella’s
              #242296
                you could just tap it and install a plug.
                • This reply was modified 4 years, 8 months ago by DAVID.
                #242322
                  Or buy some from these guys.
                  https://www.hubbardspring.com/catalog/
                  #242358
                    Take a hack saw, cut the end off of the bad one,
                    and knock it out of there. Set it on a nut and hit it
                    with something blunt to cup it again and use it
                    with a little epoxy.
                    • This reply was modified 4 years, 8 months ago by Tubs.
