Home › Forum › Ask A Member › Johnson HS 15 flywheel removal
What is the best way to remove flywheel from a 1940 HS 15 Johnson
If the threads are long enough in the flywheel nut and its not all beat up from being hit with a hammer in the past all you’ll need is a bolt.
https://www.youtube.com/watch?v=RWgE9XiIBnk
OK
