Home › Forum › Ask A Member › Johnson HS 39
- This topic has 8 replies, 6 voices, and was last updated 5 years, 11 months ago by
Mumbles.
September 12, 2019 at 8:57 am #183158
Does anyone have a shop or parts manual for the Johnson HS 39 2.5 hp, twin cylinder motor?
September 12, 2019 at 9:05 am #183161The site has some pdf manuals….
http://www.joeoutboard.com/manuals/johnson-manuals.htmlPrepare to be boarded!
September 12, 2019 at 10:00 am #183166go to this URL click on books stack ….. click on johnson……. click on red book HS is covered
September 13, 2019 at 7:55 pm #183302It is also available in my Dropbox site. I will add to it when I can unpack the U-haul box at my sister’s cottage on the lake. (now scheduled for the 20th)
September 14, 2019 at 2:11 pm #183343You will also need new Leather Primer Seals and instructions to install them. See my ad in the Classified section for order instructions.
March 25, 2020 at 2:25 pm #198339Garry,
I looked at the boatinfo site and could only find a manual with 674 pages and no way to download it. Do you think you have a manual for the old Johnson HS 39?
MikeMarch 25, 2020 at 4:05 pm #198351The url I posted was direct to the book …no need to look for the book stack and johnson menu
anyway…
you don’t need to save/print the whole book just print what section /pages you need into a PDF file on your computer then print to paper for your back up file
there is a limit on # pages you can print at a time so just do a few runs
enter a range at the bottom xx-yy select the pages you need (they turn blue) click at the bottom right hand corner to print.. then select “PDF ” as the printer name…. select the file name where to store then simply tag a name for the PDF file you want to store. on your PC
This reply was modified 5 years, 11 months ago by
JACQUES.
March 25, 2020 at 4:35 pm #198356Thank you, I will try that
March 25, 2020 at 10:07 pm #198395Also try sifting thru this site. You might find something relating to your HS or a similar motor.
http://www.austinsailor.net/manuals/20-johnson/ejs.html
Manuals were not made specifically for any model back then and one large shop manual usually covered them all.
