Home Forum Ask A Member Johnson K series spark plug wires
  • #7534
    bjensen64
      Any tips for replacing wires? I’d like to keep the terminal used on the spark plug end.
      What wire to use? I’m pretty handy with a soldering iron.
      I have a K-50 and a K-80, wires are so brittle they make a crunching sound when I try to bend them.
      #60984
        Just use a good stranded copper core high voltage wire and rosin core silver bearing solder. Pre bend the wire on the coil side so there will be no strain on the connection. . . 🙂
        #61017
        bjensen64
          Thanks Garry
