Home Forum Ask A Member Johnson model number
  • #264251
    Samuel Phelps
      Guys where is the model number on this little motor?
      #264253
        Probably on the rope plate
        Samuel Phelps
          There was a number on the plate . I’ll look again tomorrow .. Thanks ..
          #264262
          lloyd
            Looks like a Model AT. 5 HP precursor to the TD.
            #264295
            Samuel Phelps
              This is the number on the rope plate. 102127
              #264297
              Samuel Phelps
                Is that HA 15
                #264302
                reivertom
                  It’s a 1940 year model, 2.5hp. They were good running little motors. Their big brother is the AT 5hp. The ones I’ve seen ran well with some basic repairs. Anything that old will need some of that. If it has spark and some decent compression, the rest is easy. Use John Deere corn head grease in the lower unit.
                  • This reply was modified 3 years, 7 months ago by reivertom.
                  #264305
                  Samuel Phelps
                    Thanks for that ! I couldn’t find it listed . A little older than I thought it was .
                    No spark yet .. Compression seems ok . I’ll put a tester on it and see . All the connections on the mag plate are soldered and has some black paint looking stuff in everything. That’s something done at the factory right ?
                    #264318
                    lloyd
                      HA uses the same primer as the larger AT models.  You will no doubt need new leather primer seals and instructions to install them.  If so send $10.00 cash (no checks or Money orders)  and a self addressed Stamped envelope to me:   Lloyd Lautner  9289 North Long Lake Road  Traverse City  Michigan  49685
                      #264319
                      lloyd
                        And yes, the black paint looking stuff in the mag is normal.  Coils should read about 4-6 Kila ohms.
