Home Forum Ask A Member Johnson Motors corp
  • #247311
    jimw
      I have this little Johnson.On the rope sheve it says Johnson Motor Corp.By serial number it is a 1923 model.My other earlier Johnsons don’t have this .Johnson Motor corp.Any ideas why this model is different.It doesn’t have the heavy aluminum gas tank.
      Thank you for any help.Its just different than my other Johnsons.
      #247340
      Boggs74
        Every South Bend Built Johnson I have ever seen from 1922-1928, has said Johnson Motor Corp on the rope plate.
        It would help if you could post a picture for us to see for ourselves what the differences might be.
        #247342
          Original may have gotten broken. A later
          rope sheave was purchased from a dealer
          and stamped with your motor numbers.
          #247375
          stanley
            Here’s a 1923 A model rope plate.A 1923 A model with a serial number 5,000 would likely not have a cast tank.
            D72C808B-B1F2-40CD-899B-C4E4F813E101
            • This reply was modified 4 years, 5 months ago by Mumbles.
