Home › Forum › Ask A Member › Johnson QD-17 gear case seal help requested…
I need to replace the seal that is on top of the gear case, under the impeller that seals the drive shaft. I can’t find a part number. Does anyone have the number? Is there a parts manual available for this motor?
Thank you Bill
41-62 replaced by 004162 replaced by 307563 replaced by 321788. Or Sierra 18-2032
Thank you so much.
Compliments of Garry.
Thank you for the manual.
OK
