Home Forum Ask A Member Johnson QD-19 & AD-12 IMPELLER PARTS
  • #10774
    kayaker2
      I now have two Johnson seahorses QD-19 and AD-12 and they need new impellers is there a kit that has everything including gaskets? or am I going to have to order everything separately. and where is the cheapest place to get the kit or parts? I will also need to rebuild a cruse a day tank.
      Thanks
      kayaker2
      #80749
        Define "everything". If you mean a complete water pump replacement kit it is 0763758 for the AD and 0382296 for the QD. But sure as shootin’ you will come across something you will need that really is not part of the water pump. The seal parts at the top of the AD drive shaft come to mind.
        #80750
          You also need a powerhead gasket for the AD and if you remove the bearing housing below the water pump on either motor you will need a gasket for that.
