Hey folks, Another thread opened my eyes to the vast size differences in the rod & pin sizes in the 50’s through early 60’s QD’s.
The thread states that you can use the 58 and down rods with earlier QD’s, but did I hear in another thread that the 61-63 rods will work as long as I use the 61-63 pistons?
I have a 54, 57 and 58 that I’d like to restore, but better.
If this conversion works, will I be able to get away with a leaner mix ratio also?
Thanks Chris. Edit; I misread your post – thought you had the parts. I appreciate the shopping list however
Thanks Fleetwin. I thought I read that OMC went to 50;1 in the mid 60’s. Thought it might have something to do with a full roller set up. Love the classic motors, want to make them run cleaner if I can though
